I'm looking at installing a battery system and then hooking up some solar panels to it. I've switched off my gas connection and am converting everything to electric. One important thing is I want to add a continuous hot water shower which is a very high draw (60-70A) application. Seeing as the heating elements for these are simple resistors, they dont care if they are supplied with AC or DC. So by directly powering them with 230V DC it saves having a massive inverter for something that is used for less than an hour a day (and is technicaly more efficient). The same applies to kilns and forges. Most of the systems are 3 phase due to the limited current the grid and meter will supply (here it can be 63A, 80A, or 100A) but single phase systems are available.
Rather than pay $1000's to upgrade to 3-phase I figured I'm better off going straight to batteries as I wanted to go solar eventually anyway. For simplicity I want to set up the system at ~230V (i.e. 18x 12.8V 100Ah batteries) to match the ratings of the resistance elements.
Unfortunately that would be 4.5 server rack batteries so I'm guessing I'll go for a 12V battery in series array. I have seen there are distributors for Ecoworthy, WattCycle and Humsienk here.
The Humsienk are noticeably cheaper. From the reviews I have seen they use EVE cells and mostly have a solid build quality, but I don't know if these were paid. Apparently the cold cutoff switch is no good, but that isn't an issue in my climate. Anyone have any experience with these?
