I'm not far from Algonquin Park. 100% Offgrid as Hydro One wanted 55K just to cut a line up here and then they got an increase that pushed it to 70... (with transformer) Bahhh ! I use 5kWh per day max in winter BUT the home is built for purpose, and not a standard build by any means.
30kwh + per day ? = Headshot please, put me out of my agony. That is for a business with equipment, not a residence. You planning "a grow" or what.
Look at your hydro bills for every quarter, JUST the kWh used per month to get real numbers to get an "idea" of what you actually used.
It's August now and you want to be Solar Powered by the time the Snow Flies ? Dude, better smoke another big fat doobie and think on that, or spend a Lottery Winning Pile to get there.
RULE #1: Conservation is far cheaper than Generation & Storage and one must put that mindset up front.
RULE #2: Research the hell out of what you want to do... The ONLY Stupid Question is the one not asked, if you do not know something ASK !
RULE #3: NO IMPULSE BUYING !!! Never Ever do it no matter the temptation to do so. This includes Hyped / Promo'd goods, products or Methods for doing things.
RULE #4: BEWARE of the WEB Spiders who are Bench warming Wizbang Experts. If they can't show you their own systems etc... COW LICK Applied, then the Slick Youtuber University Speciallisists who promo product... like TV non-Reality Shows.
This site is full of Real World WE ARE LIVING IT & DOING folks but as expected other lurkers etc come in here too... We have folks in Log Cabins & Homes, Earth Sheltered, Net-Neutral Passive houses and conventional homes along with a few hybrids (like me).
My best advice at the start is to slow down on the "huge plan" and think things out. Little things like where you are putting the house makes a Big Difference, are you imposing it on the land or working with the land, making use of natural airflows around it, shading from trees, orientation etc. MOST IMPORTANTLY KEEP AN OPEN MIND !
Example, my place. I have No AC don't need it the house does it, It can be 40C out and it's 25C inside with doors & windows open, In winter -35C it's 24C inside and the Radiant Heating System only has to run a total of 3 hours in 24hrs to keep it there. Talk about saving a crap load of power !!!
WHAT STATE ARE YOU AT ?
Planning & Drafting ?
Already building ? if so to what level ?
Dried in ?
Intended Main Power to supply the home is 240V/200A or Higher ?
Intended supply for "shop" is 240V/100A or ?
Do you want Roof Mounted Solar (12:12 Pitch for your locale) or Adjustable Ground Mount (most flexible)
Solar Shingles are available and not just from Tesla !
Depending on property and building locations would you consider a separate powerhouse to distribute to Home & Shop ?
* That is seen as favourable by several insurance companies being unattached to a "used structure like house".
Have you considered the possibility the "shop" could just have its own Solar System with batts ?
An Example of Brilliantly Stoopid !
Fellow down the road wanted to build Hi Efficiciency home, even went with SIPS and the whole nine yards, looks great & in threory BUT due to the spot he "plunked it (a hollow)" he used a High Ranch style basement, leaving 3-5' exposed concrete ! No foam or anything covering it.... Instant Heat Sink sucking the warmth out of the house .... he get's laughed at a lot and just doesn't get it... even his contractor said it was a bad idea but the customer is the boss. The propane company does love him though.
Just a few things to chomp on for you....
Hope it helps, Good Luck.
