Hey guys,
I need help in voltage setup for EAsun 6.2 KW (7000 VA) 48V + 3x parallel Eco-worthy battery packs (51.2V) with BMS on each other, but can't communicate with inverter. Do have a few questions.
1) Is it possible and make sense to replace BMS in the batteries for the ones with Bluetooth or RJ45 port? What's the BMS inside that batteries?
2) The maximum voltage for Low DC cut-off is 48v. It seems it's near 9.5% energy left. Is it a problem? I wanted to leave at least 15% (50.4V), but no way set this amount, there is only 40-48V range.
3) Please suggest floating and bulk voltages. I set Floating - 52.2 V and Bulk - 53.6 V
4) Is it OK 60A charge current for the 150AH units?
