Hi guys, first post so go easy on me
OK, just installed 2 new 120ah Sterling (parallel connected) Lithium batteries and charging via a Victron Smart Phoenix 50 amp charger on its dedicated Lithium setting. Its bulk CV is 14.2v but as its talking to my Victron BMV 712 smart via Bluetooth network its seeing around 14.28v on the BMV monitor.
The problem is the batteries BMS trips on high cell voltage (circa 3.7v) when it gets full. This seems a bit harsh on the charger. I'm worried this sudden disconnect may damage my charger?
As I'm new to Lithium use, is this the way the batteries charge, IE I'm used to seeing with FLA the battery charger going to absorb mode then float etc, never just hard tripped like the BMS is doing currently. It just seems a bit harsh. I do know there is no float setting for Lithiums.
Should I lower the CV a bit? I have that option. Do you think it will stop the BMS hidh cell voltage trip?
Thanks a lot guys
Thanks a lot guys
