Hi All,
Long time lurker though only my first post on diysolarforum..
Have been playing around with solar, low voltage electrical and LiFePO4 for a while now with good sucess.
Am currently gathering components to complete a new caravan build consisting of a 4S 500Ah setup and am looking for something similar to a JBD / LLT Power Bluetooth BMS (e.g. JBD-SP04S020). These appear good being highly configurable and lots of info available via Bluetooth on the individual cells though for my current project I require a higher working amperage as I'll have a Victron MultiPlus 12/3000/120 feeding from the batteries. I see there now appears to be a 150A version too but am not sure if it is the same as the smaller ones and if suitable?
My query is whether it is possible to use the smaller JBD Bluetooth BMS' and have them trigger external battery disconnects / isolators such as a Victron BatteryProtect for the low voltage cutout and also high voltage, high / low temp cutouts? (Am thinking to set the Victron BatteryProtect's slightly higher and lower than the BMS as a failsafe).
I have previously used standard Daly BMS' though from what I have seen the Bluetooth info from their smart BMS' isn't as advanced as the JBD and I am also not keen on having to have them pre-programmed before purchase.
Can anyone shed some light on the subject or offer any further BMS / disconnect recommendations please?
Thanks Peter.
Thanks Peter.
