I recall seeing a Guy from the USA where he got a nasty electric shock from the solar input terminals on his SPF5000ES Grow Watt inverter.
The thing that was surprising is that no solar power was going into the input terminals. I was not impressed with the way he was testing this by shorting each leg of the DC input to the case of the inverter and getting quite large sparks.
Anyway I thought I would check my own inverter by measuring the voltages on the input DC lines to the case. By the way I am in Australia so do not have to worry about split phase issues like in the USA. With no solar input going into to PV input terminals of the inverter I measured 206V DC on each line both the positive and negative lines with respect to the case. This seems potentially dangerous to me. Sure zero volta across the lines but a dangerous voltage (no idea of its source impedance) with respect to the case (ground) with no solar power going in? I checked my other inverter and its the same.
Surely this is a design fault.
Anyway see what other people say
