Surfsailspear
- Dec 11, 2021
- 10
I am adding two 24v 200w panels to my sailboat. They will each connect to separate Victron solar charge controllers, the controllers will connect to the positive and negative busbars of the house battery bank, which will be two 12v 200ah Chins LiPO4s. The alternator will connect to the start battery, and between the start bank (105ah 12v AGM) and the house bank I will have a Victron Orion Smart 12/12 DC2DC 30amp charger to handle charging from the engine.
I have two questions: Will the Victron 100/20 solar controllers be the right ones vs the 100/30? And in general, does this set up look correct?
Thanks in advance for your input. As this is a high level design I left out the breakers etc.
