bsr
Hello
I am getting battery high voltage warning/ error on Schneider Conext XW PRO inverter.
High Battery Cut Out is set at 58.2V.
I have two EG4 PowerPro AllWeather Lithium Battery | 48V 280Ah | 14.3kWh LiFePO4 connected in parallel .
Please let me know if there is a way to find the correct voltage value for these batteries.
Thanks.
bsr
These are the battery spec. :
Thanks.
bsr
2024/12/31 11:25:09 -0500 | 75 | Battery Over Voltage | Cause: Battery voltage is above the battery voltage limit sent by the external BMS. | |
2024/12/31 11:22:37 -0500 | 49 | DC Over Voltage | Cause: Battery voltage is (BattV), which is approaching the High Battery Cut Out level of (HBCO). Solution: Check battery cables. Check for the correct battery voltage at the inverter's DC input terminals. Make sure the DC source is regulated below the high battery cut out or increase the High Batt Cut Out setting. |
