Ok, seems like a simple question but want clarification..
Cells; Eve 3.2V 280AH
Capacity test
In wanting to do a capacity test on my eve cells,
Say the cell is at 3.2V
IF I were wanting to bring them up to 3.5V, charging them at 3.5V with my DC power supply ( 30V, 10 A max) shows maybe 2 amps.
If I turn the voltage up on my charger to say 4 or 5V, the current goes up to 10A (which would take less time to charge up - of course I would monitor it until the cell reaches say 3.4-ish then drop my charger to 3.5V so as not to miss my upper target).
Is charging at a higher voltage initally a bad thing?
I would not think so, consider this bulk charging.. the only way to increase the amps is to increase the voltage.
If it ok to charge say at 5V, how about 12V, with a charger I have which can put out 45A?
Thank you for helping to clarify this.
I
Capacity test
I
