We are considering building a battery bank for home - probably 30 kWh to 50 kWh range, 48 volt. In the looking I've done so far, building a diy battery bank from cells seems like the lowest cost.
This is for back up power, and for "load shift" purposes basically. We're looking at electricity pricing that has very high rates from 4pm to 9pm, in exchange for very low rates overnight.
(we could then charge EVs and the battery bank overnight).
Question is, what is all involved, what parts and equipment (including tools) are needed? What cost estimate am I looking at? (to determine if the idea is feasible) I do have electrical background, including solar, just not in building batteries.
Anyone know good sources for Canadians - either to buy in Canada or to have shipped from oversea?
The cells I've seen seem to come as large as about 300 Ah. So probably looking at either a 2p16s or 3p16s?
I think a 200 A output would suffice, probably would see a 10 kW inverter at most, more likely around 5 kW (not covering whole house).
Preferably something that gives some level of monitoring (like SOC). Might get Home Assistant, but not sure.
Parts that initially come to mind include 48 LiFePo4 cells, a BMS (or would it be BMS for each 16 cells?), wiring including main fuse or breaker?, whatever the cells would be stored in (preferably on wheels), etc.
I'm particularly asking about the battery bank part now, but will also be looking into inverter chargers.
