Hi gang, new boy here.. so the background >
I live full time on a sailing boat, have done for many years now. Just taken delivery of 4 x 300Ah cells from Jenny at forget the name but cells look perfect. Already onboard there is a reliable home built monitoring system based on a raspberry pi which records data once a second - image below are data from a victron smartshunt as an example.
So plan is ...... probably esp32 based BMS, ads1115 (accuracy down to a mV or 2) will measure the voltage of each cell, a ds18b20 thermometer will record the temperture - one on each cell maybe?
Then the esp32 will control relays - I've order 2 of these>
So too hot , volts too high/low the relay(s) get switched off. Maybe fit another smartshunt to monitor current in/out.
Cells should get enough charge most days from solar to get the SOC back up after the overnight loads. Not sure of what SOC the cells will cycle at though should be an easy hopefully very long life, At the moment I've 2 x trojan T015's (12v, 225Ah) which go down from full to maybe 70% overnight. There are 2 new Trojans which will stay but probably rarely used.
So far I'm sort of OK with it, keeping an open mind and it will be little careful baby steps then look at the graphs to see what's going on.
So what am I missing?? What should I be asking??
Thanks in advance
Thanks in advance
