2Big2B
Free Wheeler
This was originally posted as:
"The Champion 2000 inverters is on sale at AMAZON for $499".
Well, long story short, AMAZON, or its supplier, blew it. They kept having shipping issues. I think it "fell off the truck" somewhere. Whatever. After two weeks and three attempts I gave up. It wasn't meant to be.
Pity. The Champion 2000 dual fuel is probably the best bang for the buck right now.
I researched it. It is the closest thing to having a Honda for a third of the cost. And it runs propane.
There is an important break in procedure though, that must be performed properly. It involves changing out the cheap chinese spark plug and running it for 5 hours at various loads; and then draining and changing to oil to remove the released metal shaving debris. It is a lot of hands on babying that I some people probably don't bother with. Its not fun.
BTW, if you get a Champion 2000/2500 to use primarily on propane, I would personnaly use the irridium version of the NFK BPR5HS Spark Plug, the NFK BPR6HIX, gapped tighter to about .22 - to tweak it for propane.
Buying a poorly broken in inverter generator can be a hazard worth considering when buying a used one.
Nevertheless, I found a good used Honda EU2000i for $500, delivered and demonstrated. It started right up, and ran clean and quiet. Its a Honda.
It has gasoline in it but I plan to convert to propane .
Hutch Mountain and Grenergy sell the most popular tri-fuel conversion kits, both at $299. There are others on ebay that are cheaper, and they all seem to use the same commonly available parts; with a large low pressure regulator being the main component. I could probably build the same kit myself sourcing the parts from Alibaba and Amazon for half the price. But should I?
The tricky bit is adjusting the low pressure regulator to get the right mixture setting. For $299 you get some hand holding if it won't start. That is the tradeoff. I need to think about that.
Any advice?
Any advice?
