I bought a klein rt250 tester and I can't figure out why its showing the error its showing.
Shows hot/grd reversed and it shows 30 volts.
Everything working fine in the house. Also all outlets check out at 120v using a voltmeter.
If I put one of those 3 to 2 prong adapters on it the tester shows 120v and open ground.
I even tested it on a circuit that comes straight off the inverter. Same results.
I visually verified that outlet had an L1, neutral and ground running directly to the L1, neutral and ground on the inverters lugs.
Suggestions?
Suggestions?
