Hi all,
I recently revamped the electrical system in my RV. I've got 680W of panels on the roof wired to a Victron 100|50 solar charger, 300 Ah of Battleborn lithium batteries, and a Victron Multi-plus 3000W inverter-charger. We took the RV on a monthlong trip in May and everything seemed to work well. I opened up the battery compartment the other day while doing some work in the coach and decided to crank up the A/C (with soft start). I don't plan on running the A/C for long periods with battery power but would like to be able to cool off the RV in the evening for 1/2 hour or so.
After the A/C had been running for a half hour, I noticed that the wires, distributor, and shunt all got very hot. I've got 4/0 ga wires running between my batteries and the inverter. The longest wires are less than 3 ft (running to the inverter). My BMS says i'm at about 140 A of current with the A/C compressor running and I measure about 0.05 V drop across each cable. This is about 10X what I calculate should happen for my cable length though I don't know what to expect for losses in the connectors.
Is this normal behavior or do I have a problem?
