For a number of reasons, I've decided to convert much of my house's electric usage to 12VDC powered by solar (and, soon, wind). I validated that it was doable with a 100W panel, 65AH AGM battery, and a cheapo 40A charge controller from Amazon. Now I'm ready to scale up to full-house 12VDC where it makes sense to convert things. But I want to make sure that I've got my bearings, and I have a few nagging questions still.
For what it's worth, my average "peak hour" power usage on 120VAC is 200-300W, with an absolute peak (everything sensible turned on at once) of about 500W. Of course, I occasionally run my microwave and stuff akin to that, but those are more "burst" loads and I'm not accounting for them in any calculations I'm doing right now. Also, wintertime brings space heaters, and I'm not sure how well they fit into the 12VDC lifestyle or if those should stay 120VAC. (But I touch on heating below!)
I also do not intend this to be a grid-tie system. I intend this to be its own self-contained little thing.
This is a long post, mostly so you can all (hopefully) see where my thinking is, in hopes of helping me avoid expensive (or life-threatening!) mistakes.
I split this into two posts, to help make it easier (I hope) to quote reply on what I have chosen and what is all questions for me. I hope that's acceptable around here.
What I've picked up so far:
- 200 AH deep-cycle AGM battery - I'll end up with 4-8 of these, depending on how much capacity I end up actually wanting. 4 feels "right" right now from what I've been able to calculate, though... Or am I totally under-speccing and should have like 16 of these batteries?
- Xantrex C60 - As a load controller (LVD), since 60A is more than sufficient for my needs as far as I've been able to calculate so far.
- Battery disconnect switch - Safety first! Should I add one in line with each controller? Or just the load? I learned long ago on 120VAC to never trust a breaker/fuse alone.
- 12VDC light bulbs - I've started converting fixtures, running new LV wiring to them, and adding new LV switches and dimmers (I never knew I wanted dimmer switches for my porch lights before!). Some fixtures wanting replacement got replaced at the same time. (Also, this house is old enough to have knob & tube, so it's also a great opportunity to pull out 100 year old wire, which I'd have to do soon for 120VAC anyhow.)
- Various 12VDC fixtures, to ensure adequate lighting on 12VDC alone. One example.
- Even my main PC is now 12VDC (and, of course, car chargers for the laptops).
- I've surely missed a few things.
- 60A breaker for my C60 load controller. Is something like this appropriate? Does it go on the positive or negative leg, or does it matter?
- Roof-mounted 445W PV panels - 4 of these seem like a good start. But should I go for 8, considering no more than 60A absolute max drain on the battery bank? 16 (though that honestly feels like overkill for PV + wind with 60A max drain)? Are these a good deal? The price seems good and they claim to have a warranty that's almost too good to be true, so I'm honestly a bit suspicious.
- Charge controller(s) for the above panels - Can I run them all through one controller with a PV combiner box? Should each panel or pair of panels have its own charge controller? Do I want PWM or MPPT for real? From what I have read, PWM is better on less bright days to be able to get charging at all, while MPPT is better at sucking the power from the panels once they get above the threshold initially. Is that correct? For what it matters, I'm in Michigan's Lower Peninsula, so short winter days and occasional snow are a thing.
- For off-grid entertainment, a 40" TV (the largest 12VDC I've found, so if anyone has better options, I'm interested) and a Blu-Ray/media player (this also looks like the only viable choice, and I'm waiting to hear from them as to its availability in hopes that it won't cost me $250 on Amazon/eBay/etc.). I can operate my Amazon Fire Stick off USB or my Roku off 12VDC, as well.
- Some exterior lighting solutions besides just retrofitting my front porch. Things like this look interesting to me for replacing my various not-great solar motion lights.
- An inverter. It feels like a good idea to have one of these available, for "just in case", if nothing else. (Though my 120VAC panel has a manual transfer switch, for eventually adding a generator to that system, so ideally it *will* be "just in case" for the long run.) Probably 2000-4000W since I should have enough juice on store for that much maximum power if it's needed.
- A wind turbine and associated charge controller. I have a company in mind to order from, but they're out of stock of the one I want for a couple weeks. I won't go into detail on that aspect of the system as this is the Solar forum. (My diverter questions are still relevant for the wind, too, though, I suppose.)
