PlainJay
First time posting and most likely several more to come. I am designing an off grid system for a large aluminum hull houseboat (located in Southern KY). I would like to use 48v server rack batteries matched with 2xEG4 6000xps. The storage location for the batteries will be in the front hatch. It will be dry, but not temperature controlled. The off-grid system will rarely be used when the air temperature is below freezing. Is it sufficient to use batteries with just low temperature protection? Or should I use batteries with heaters? If heaters, is there a preferred brand based on experience? Thanks, Jay
