kgingeri
Kamping Powwa
Hi All, I'm in need of some advice...
Components to Connect:
Questions/Concerns:
I have a Canadian Solar panel (CS6P-230P) that gives VOC: 36V AOC: 8.5 - rated for 230 watt. OC measuring with a meter, the panel voltage in sun is 36.4 and amperage wise looks like 8.5 (I'm in southern Ontario, Canada - these are today's measurements). Here's specs for equivalent.
I am getting a "MAXOAK Power Station 500Wh 300W Bluetti AC50 Solar Generator" that is rated for "4-5Hrs to Recharge it Fully by a 120W Solar Panel".
Another spec given is "Open Circuit Voltage(OCV):14-40V/Max.10A, Max.120W"
Questions/Concerns:
My concern is that the panel is too large for the MPPT charger in this device - is this correct? My panel can put out 230W.
Tho the "Open Circuit Voltage(OCV):14-40V/Max.10A, Max.120W" mentioned above falls within my panel output EXCEPT for wattage.
Does the "Max 120W" mean that's the maximum the CS50 will use to charge, but it's ok to give more?
Does it matter that the panel produces 36V and higher wattage or will the power station limit such?
Should I be putting a primary SCC on the panel and charge the power station via 12V input instead?.
If so, how do I match a SCC? Would a "Victron BlueSolar MPPT 75/10 Charge Controller - 10 Amps / 75 Volts" be adequate?
How best do I connect these two? (This is for a camping setup, so I'm not concerned about equip close to spec, as apposed to future proofing etc.)
Thanks in advance!
PS: Not sure I understand how wattage and voltage plays for charging/input setups. I know most panels put out 18VDC and that's what a lot of devices are built for. So a bit uncertain if I can go on voltage and amperage alone or what? I know wattage load is whatever a device requires, but is too much on input OK?!
