rubenscamp
Hello. I searched the Forum but couldn't find an answer to how could I know if cells were damaged by the cold temperature.
Here's what happened: I have a 12V 560Ah (8 x 280Ah EVE cells) battery bank in my RV. The BMS I am using is a Daly 250A. The batteries are in an box with a small (60W) fan heater controlled by a thermostat to keep it above 10 C. Everything seemed to be working fine until few weeks ago when we had several days with very low temps (-20 C). The RV was not heated. One morning I checked the battery and the voltage meter was beeping with a low voltage alarm. I used my Renogy 2000W inverter/charger to charge the batteries (at this point the thermometer in the enclosure was marking +10C, as expected). While that was happening I notice the BMS couldn't keep the cells balanced and shut itself off with voltage imbalance protection.
Unable to charge the batteries in the RV, I brought them inside, disassemble the pack and began to top charge them using my power source. They were at about 3.4V and I top them off to 3.65V. To my surprise, it took just a few hours to go from 3.4V to 3.65V, which I found suspicious. Anyway, I put the battery bank back together (this time only using 4 batteries, so I could keep a close eye on the balance) and re-connected the BMS. As a quick test, I connected a small 10A charge and notice that, although the BMS was keeping them balanced, the cell voltages dropped very quickly from 3.62 to 3.45V. Again I found it weird considering it's a 280Ah battery.
I am now beginning to suspect that my heated enclosure was just heating the air around the cells, but the cells themselves could be at low temperature (the thermostat temp probe was stuck to one of the cell walls though).
The question is: how can I be certain those cells are OK? Is there a quick test I could perform to find this out?
Thanks in advance.
Thanks in advance.
