Thanks for your replyWhile there are some tracker mechanisms, they probably cost more (per kWh harvested) than more panels.
If you populate your entire roof with panels (or as much as allowed if walkways for fireman are required), that will get full sun in the morning and the panels will never shade each other.
If you use either a motorized tracker or a fixed tilt to get more sun later in the day, such tilted panels will cast a shadow on other panels further down the roof. You would have to put less panels up to avoid that until somewhat later in the day when a single row of tilted panels at he ridge would shade the entire roof. Only a panel casting a shadow on the ground to the East of your house is capturing light that a flat array would not have captured.
To get more light later in the day you need either panels on a West face, or panels that cast a shadow on the ground.
Sometimes people make an awning that shades the yard. Could you make an awning tilted up rather than down? It would catch lots of afternoon sun. If not to steep, it wouldn't shad the roof which could catch morning sun.
Or, you could make a rack that starts at the ridge and slopes up not down (a West facing PV panel "roof" above your existing roof.) It would be quite tall.
Any particular reason you want Western exposure and aren't happy with just Eastern?
If anything, I would consider a Southern tilt of panels, and spacing between columns of panels, to catch the same amount of sun in Winter with half as many panels as required to cover the entire roof.
As far as west facing, I can do that on my garage roof, but then would need a way to switch the output at noon, from the ones on the back of my house roof, to those on my garage roof.
But you can get by with less total wattage of MPPT controller by connecting both arrays to a single controller.Put each array on it’s own MPPT controller, connect both to the battery.
No switching needed.
I don't know where you find 2kw of panels for 400.00. I was looking to save roof space with a panasonic over 350 watt panel so I wouldn't need to series them, just 6 in parallel . It runs around 345.00 per panel. I can get cheaper panels with lower output, but don't have that much roof space. I think I will get the rack and mount on my garage roof first. That will take the longer wires to the power shack, and is an older roof so I can afford to learn on it. Then when budget permits, do the east facing house roof using the same length wires. If you're saying that I won't be losing amps by having both sets of panels connected, then the 2 roof option would be the best one. Thanks, and appreciate any input you may have on where to buy, low cost, high wattage panels.By "Walkway" mean one required on top of the roof for firemen to access, to hack a hole in the roof for venting smoke - depends on building codes. Originally no requirement. Then 3' on two sides and top edge of roof face. Then 3' walkway on whichever edge fireman would access plus 18" both sides along ridge (to hack vent holes). You need to see what PV codes are for your city/county/state and follow those.
If panels are flat on a flat roof, or on an East or West facing slope, then in winter the oblique angle of light from the sun produces significantly less power. Light passing through a small rectangular area (representing panels aimed directly at the sun) is spread over a large area of panels. The small area is how much light you capture, power you can produce.
With East and West, you will get a lot of power during summer but little in winter. Not bad for net metering, where power is "stored" as a credit on your bill, but for actually powering the house during grid outages or offgrid, not very good.
No need to switch anything. Just have a series string (however many panels add up to proper voltage) on the East roof, and connect in parallel same number of panels on the West roof. (Or, some inverters have multiple MPPT inputs, in which case connect one string to each.) So long as two strings of PV panels are same length, they can be connected in parallel. Peak output is determined by area exposed to sunlight, considering the angle between them means less area than if all oriented the same. You will get to install more panels than if all one one face of the roof, produce more kWh/day.
2x4 roof joists are plenty to hold PV panels. Our "no mechanical permit required" rules apply if PV mounts are no more than 40 pounds per attach point and some number of pounds per square foot (I forget the number.) The weight of PV panels isn't much; mine are around 2 pounds per square foot. Probably they figure at 40 pounds, screws into sheathing are sufficient. If you lag screw standoffs into the joists, it will be very secure.
"Since I only need 1.6 kw to charge my battery in 5 hours, and I'm planning on 2kw worth of panels"
Check a solar calculator for your location and roof slope/orientation. It will be fine in the summer, but in winter some areas get as low as 0.8 hours effective sun, and that for fixed orientation facing South. That would only deliver 1.6 kWh/day, not 1.6 kW x 5 effective hours = 8.0 kWh/day. 5 effective hours is a reasonable average over the year, but you need to plan for shortest day of the year which might be only 2 hours effective sun.
You can get 2kW of panels for as little as $400, so how about at least 4kW, half facing East, half facing West? Probably a bit more, since 4kW STC of panels is more like 3.5 kW actual output.
My roof faces east, gets plenty of sun in the morning, but not direct sun in the afternoon. Is there an auto tilt mechanism to keep my panels facing the sun?
Check out SanTan solar.I don't know where you find 2kw of panels for 400.00. I was looking to save roof space with a panasonic over 350 watt panel so I wouldn't need to series them, just 6 in parallel . It runs around 345.00 per panel. I can get cheaper panels with lower output, but don't have that much roof space.
