Hello all,
Ive got several lithium ion packs made of 18650s. Occasionally they will go offline due to being at or below the minimum voltage per the BMS. At this point they will not take a charge either. If I read the voltage on the output side of the BMS it’s essentially 0 volts. On the Input side it can show around 11 volts on down. Is there a way to reset the BMS to turn it back on to allow it to charge the battery pack? When we receive these packs they are turned off and require us to plug them into the equipment to charge them. Sometimes they sit to long and you cannot turn them back on. The battery that is.
These are commercial made battery packs for medical equipment. Customers think they are dead but the cells are fine. I’ve got several of these packs that are nominal 14.8 volts and will charge up to 16.8 volts at 11 amps.
Thanks.
Don.
Thanks.
Don.
