fromport
Only with more than 2 panels/strings in parallel you need fuses.Hi Tim, so looks like 20amps. I included the panel label below. Also included is a diagram of the set up with where I understand the fuses should go. Look correct? So I need four 20amp fuses for this set up? Sounds like we have similar setups. I also have 6kw of panels going into the two growatts into 2 EG4 batteries. Thinking of buying one more battery actually. Thanks so much again for your help. View attachment 100901View attachment 100902
Not when you combine just 2 to an inverter
