Vanytoy
- May 31, 2020
- 7
Hi,
I'm from Belgium and i'm going to build an expedition truck in a 24V system. I need in total 12-15 Kw in battery capacity inside that truck.
I will also use around 3000w of solar panels on the roof. For the daily electricity i want to use a inverter of max. 5000W. (210A)
This truck will drive in Siberia and other crazy country's and also Off Road.
For safety i need always (backup) energy for in this sometimes deathly environment, and this for a minimum for 5 to 10 days.
First question:
I think i want to use prismatic LiFePo4 cells.
But i have read somewhere that it is better not to use too large cells (max 200A) in conditions with a lot of vibrations and shocks. This would affect the battery life or even damage them.
What is your idea of this? Maybe someone of you here has more information or has a graph of whether or not this is the case?
But with smaller cells you have more connections! So also more chance to have a damage or bad connections i think?
It is crazy but all what i build must be useful for more things in one, and 100% reliable and also possible to rebuild in a emergency crisis so there is always power. Because no electricity is also no diesel heating!!
Second question:
Can i use two or more BMS's in serie or in Parallel? Or are this special types of BMS's?
Maybe is there a another (better) way to management the battery's?
Last question:
Is it better to build for example 6x 12v battery's and use this to make a 24v battery? And use 3 or 6 BMS's?
Or, for example, if i use the 100Ah cells,
Is it better to, connect 3 cells in parallel (300Ah), and then connect these blocks in series 8 times to get a 24V battery?
And do this double for the total of energy i need and i can use also 2 bms's?
I know it is all crazy but stuck in -58 degrees F and a 50 mph wind is this also!))
All information or ideas are welcome!
I read a lot here on the forum and i find very interesting things here!
Thanks,
Yvan.
First question:
Second question:
Last question:
Thanks,
Yvan.
