I got some lipo cells 3.7V 2.2AH X 2 each with their own BMS connecte to the two parallel cells, my question can these cells work just as they are or do i have to remove the BMS board, and then i could use one BMS in a 14S10P or 20S14P to achieve the kwh i need, secondly i hooked up a 20S pack and i noticed one cell in the bank charged up before all the other cells shutting down the charging to around 77 volts, do i have to remove each 5A BMS per cell and just use one 20S for the complete pack so i can get 84 volts finallly
All comments are welcomed for education
Thanks
Thanks
