AlexanderKristiansen
- Mar 18, 2020
- 96
Do you have a 100 watt incandescant bulb per chance?
No, only LED bulbs 3,4 or 5 watts, I'm afraid...
Yes, I have plenty of wires here. Maybe PM is better?Or a a very long run of wire?
Lets keep it in the channel so others can help and/or learn.Yes, I have plenty of wires here. Maybe PM is better?
Or just put a load on the pack and it will settle to 3.35 quickly. I have cells that settle more slowly than others. It is less of a problem and more of an idiosycrousy.Or a a very long run of wire?
How low? And I guess you mean on the inverterA short term solution is to set your Constant Voltage (Absorb) lower. Many here use 3.4 volts per cell and the runner cells stay with the pack at that setting. It is hard to tell how serious the imbalance is at resting voltages. Do we have data during end of charge cycle after this top balancing? Your earlier picture was helpful.
Or just put a load on it and it will settle to 3.35 quickly. I have cells that settle more slowly than others. It is less of a problem and more of an idiosycrousy.
Yes, I agree. As I mentioned above it may not be a problem until we see the result of your next charge cycle. Others can benefit from that information.Lets keep it in the channel so others can help and/or learn.
I mean on charger. If your inverter does both then yes on inverter. How low would depend on what it is now. Try 3.4 volts per cell. There is very little capacity above that.How low? And I guess you mean on the inverter
I guess this is "Bulk charging voltage (C.V voltage)" in the manual? Yes, I can lower it. How low?Yes, I agree. As I mentioned above it may not be a problem until we see the result of your next charge cycle. Others can benefit from that information.
I will repeat my suggestion that a solution just might be lowering your CV setting on your charger. Can you do that?
The inverter is also a charger and MPPT. I cannot set CV for each cell, just for the pack.I mean on charger. If your inverter does both then yes on inverter. How low would depend on what it is now. Try 3.4 volts per cell. There is very little capacity above that.
I am giving cell voltages for the benefit of other readers. The concepts are the same whether someone has a 4S pack or 16S pack. Cell voltage is the issue so it reduces most confusion if cell voltage is used. Since.that comment I reread your post and noted that you have an 8 cell pack. I will try to remember but science concepts and the laws of physics are easier for me than the details of every posters pack. Sometimes I can't remember why I went to the garage.I cannot set CV for each cell, just for the pack.
How many days can you go without the battery in service?
You could try my suggestion from earlier and just enable balance during rest and let the pack sit for a day.
Report back tomorrow on the cell delta after 24hours.
buy a capacity tester and connect it to the cells terminals.I think I will just pack up my things and head home. I will bring the cell with me. Can you please explain to me in very simple terms how I can discharge just this one cell?
I read somewhere that it's important to either connect the leads to the cells before or after you turn the power supply on. Dont remember which way is the right way. Do you know which way is correct?
The issue is the voltage of that cell when charging in the pack. Everything is relative. Taking the cell with you will not help you solve the problem. Leave it there. By your next visit it will probably settle close to the others. Have a nice drive home.I will bring the cell with me.
I don't know what you mean by it was difficult to get the cells to the same voltage?Long story short, the top balancing did not go well. I charged the cells one by one, but it was difficult to get them to the same voltage. Now my battery pack is even more unbalanced. I need to discharge one 3,2V cell. I'm at my cabin, I cannot go to a shop and buy a resistor.
Is there an easy way to discharge this cell from 3,55 to 3,35 volts? (@Bob B @Gazoo @Supervstech )
That is a big disparity. But cell 8 wasn't the highest cell when you first posted. Cell 4 had the highest voltage.Cell 1-7 is 3,34-3,35, the 8th cell is now 3,53
