Newbe Europe
I’m new to electricity and Solar panels etc. I’m about to create my first DIY solar system project. It’s meant for powering a small workshop where I’ll be using only 1 or 2 machine at the same time.
This project is on a budget and so far I have 22 used solar panels ‘Soluxtec Das Modul Multi Serie FR60 250Wp’ and a second hand ‘new in box’ Growatt SPF 5000 ES’ hybrid inverter. I intend on using it without a battery pack and no grid tie. Since the inverter has only 1 string input I need/intend to use a combiner box 1200V DC/32A. I’m in Europe, so will configure 220V/230V monophase at 50/60Hz.
My question is regarding the way I should connect the panels. Should I focus more on de VDC or the A input of the inverter input for maximum results, or should I also consider the output?
INVERTER SPECS:
Inverter Output: Rated pouwer 5000VA/5000W, Surge Power 10000VA, Efficiency 93%
Solar Charger: max PV Array power 6000W, MPPT Operating Voltage 120VDC-430DC, max PV Array Open Circuit Voltage 450VDC, max Solar charge current 100A.
Solar panels: Pmax 250Wp, Isc 8.75A, Impp 8.25A, Voc 37.90V, Vmpp 30.40V, max System Voltage 1000V, max Series Fuse 12A
If I’m correct and connect 2 series of 11panels parallel on a combiner box, I end up with 2x 416.9V/8.75A, resulting in 1 ‘combinerbox output/inverter input’ of 416.9V/17.5A(=7295.75W).
(at first glance this seems my prefered configuration, since I use all the available panels and create maximum W)
But if I use 3 series of 7panels parallel on a combiner box, I end up with 3x 265.3V/8.75A, resulting in 1 ‘combinerbox output/inverter input’ of 265.3V/26.25A(=6964.125W?)
(1panel will be ‘backup’/’spareparts’/’unused’ panel)
And if i use 4 series of 5 panels parallel on a combiner box, I end up with 3x189.5V/8.75A, resulting in 1 ‘combinerbox output/inverter input’ of 189.5V/35A(=6632.5W?)
(2panels will be ‘backup’/’spareparts’/’unused’ panels)
Although the V and A of my ‘preference’ seem to meet the specs of the inverter I think I’ll use this configuration unless the ‘W’ create a problem since it exceeds the specs of maximum ‘inverter output’.
If I forgot anything, or if somebody needs more info, just ask. I'll also try to upload/attach all the information that I've gathered so far including an intended schematic overview.
Can anybody advice me on which configuration would be most suited?..... Thanks a lot!
INVERTER SPECS:
