Ohms_Cousin
- Nov 6, 2020
- 59
I am new to mppt's - never used one before so coming to terms with how they work.
The inverter I am looking at gives these spec's;
The panels I am interested give these spec's;
and the **COLDEST** temps at my location (I am in a hot location but it gets a bit chilly at night - 62F/16C - in June / July we have to break out the jumpers and blankets)
So it reads to me as 3 Mppt trackers with each tracker having 2 strings and each string is 22A with 450V max voltage and the Mppt range being 250V to 450V.
Seems that I could put 9 of the Risen 700w panels in one string on each of the Mppt's (9 x 47.17 VOC = 424.53v) with a Vmpp of 39.64v to give 356.76v.
Impp is 17.68A - so fits into the 22A limit.
So it seems 9 of these panels are within the working range of this Mppt setup as the temperature rarely gets cooler then about 16C or 62F - so panel voltage wont spike because of cold temps.
What i am not sure about is if that is 22A per String for each of the 3 trackers ?
This is my first time to try to figure out matching panels to an Mppt so any guidance gratefully accepted.
