Ok, after months of accumulating all my components for a remote cabin solar electrical system I finally not only have all the components but I now actually have my cells {280AH variety) from Amy (???). They arrived 3 days ago only 107 days after ordering them. Of course, I knew going into this that it would take months and I allowed for it. I must say they arrived supremely packaged. I was impressed. Initial voltages revealed that all cells were within a couple hundredths of a volt. All around 3.27v.
I proceeded to top balanced them as prescribed by many members on this forum until the charging amps dropped to .15amps. As a side note, it certainly is true that one can not tell the amount of charge on a cell by voltage (with LIfePo4)-----I top balanced at 2.6v per cell and it took hours for the amps to drop.
I then capacity tested them with a draw of 50 amps. I stopped the test when 283AH had been consumed. Voltage measurements 10 minutes after disconnecting the resistive cabling was done. Most were in the 2.72-2.77v range. One cell was at 2.84v and another was 2.66v.
My question is this; what voltage variation is "acceptable" with a high of 2.84v and a low of 2.66v? I know that no one cell will be identical to another and thus I expect some discrepancy. I just don't know what variation is "acceptable" and what is "concerning"?
Overall I have to say I am rather pleased with the cells received from Amy. They certainly were not the least expensive option for 280AH cells but it seemed as though purchasing from her was less of a risk of a bad experience than with some other sellers.
Looking forward to hearing answers from the members here.
