MrSteve
- Dec 24, 2019
- 21
Hello,
As some might have read in an earlier thread I am helping a friend setting up an ESS system, not off-grid.
We are looking at the Multiplus 2 48/5000 with separate smart MPPT 150/60 or the EASYSOLAR 2 GX 48/3000
Maybe a silly question, but when the 48V batteries are full, how much of the exces PV can be
feed "directly" back into the grid using the EASYSOLAR 2?
I see the mppt inside the EASYSOLAR is a 250/70 can handle 4000W PV input,
but the inverter on the 48/3000 model can only supply 2400W at 230V so this would be the max wattage that can be fed back into the grid correct?
We are looking at installing a 3200W PV array btw.. lets say 80%of that figure on a decent day that's 2560 Watts
So that is close to the rated 2400W inverter power. But at max performance of the PV we lose at lot.
Maybe the EASYSOLAR 2 5000 or the Multi2 5000 with separate MPPT would be a better match
as they can most likely feed back 4000W into the grid..?
Or am i missing something?
Thanks for your reply!
Steve
Steve
