mortenmoulder
I am using klatremis/https://github.com/klatremis/esphome-for-deye for communicating with my SUN-12K-SG04LP3, installed on an ESP32 with PoE. It works great, however, I cannot seem to change the update_interval to anything below 20sec, otherwise my log is filled with:
and:
and I get no updates at all. Even when I set it to 10sec. At 20sec I get pretty consistent updates, but not all the time.
Code:
[11:07:24][W][modbus_controller:183]: Duplicate modbus command found: type=0x3 address=130 count=1
[11:07:24][W][modbus_controller:183]: Duplicate modbus command found: type=0x3 address=141 count=3
[11:07:24][W][modbus_controller:183]: Duplicate modbus command found: type=0x3 address=145 count=2
[11:07:24][W][modbus_controller:183]: Duplicate modbus command found: type=0x3 address=148 count=12
[11:07:24][W][modbus_controller:183]: Duplicate modbus command found: type=0x3 address=166 count=12
[11:07:24][W][modbus_controller:183]: Duplicate modbus command found: type=0x3 address=653 count=1
[11:07:24][W][modbus_controller:183]: Duplicate modbus command found: type=0x3 address=655 count=1
[11:07:24][W][modbus_controller:183]: Duplicate modbus command found: type=0x3 address=672 count=2
[11:07:25][W][modbus_controller:183]: Duplicate modbus command found: type=0x3 address=676 count=4
and:
Code:
[11:09:19][W][component:237]: Component modbus_controller took a long time for an operation (127 ms).
[11:09:19][W][component:238]: Components should block for at most 30 ms
