There is a longstanding debate about whether wood burning is an environmentally sound practice or not, with many pointing at the fossil fuel based inputs required as a major objection. And as anyone who has relied on wood heat knows firewood is labor intensive no matter how you handle it.
I'm looking to share methods and ideas for selecting, harvesting, transporting, processing, stacking, seasoning, and loading firewood that folks have come up with to keep the both the labor and fossil fuel inputs low and the burns efficient.
I'll start.
I have about 25 acres of which 12 or 13 is mixed hardwoods and pine. I've found that I can harvest 3 to 5 cords annually just from accessible standing dead or windfall trees.
I use an Ego electric chainsaw with an 18 inch bar and have 4 of their larger 7.5AH batteries for it and my other tools. I generally fell, limb, and buck the logs to finished length in the field before hauling them back to the barn for spitting. By the time I run through 3 or 4 batteries I'm ready to take a break. The Ego works pretty well for me but I occasionally wish for a larger saw when I have a big oak or pine to cut. I also have a PTO driven chipper and grind up some of the straighter limbs for use as garde mulch, most of the trash I drag back in the woods to rot.
The hauling is done using my diesel tractor loader, so this is my sole fossil fuel input in the firewood process. Once at the barn I split using a light duty electric/hydraulic splitter, then stack the wood under cover for at least a year of seasoning, preferably two years. I do notice more efficient burning even after a second year in my relatively humid climate, but it's hard to get that far ahead of the game. The little electric splitter gets the job done but I'm interested in exploring getting something faster and less labor intensive, like an electric kinetic splitter or a small firewood processing system.
I have two stoves, one in the house and one in my greenhouse. I tend to burn the pine in the house and the hardwood in the greenhouse. I try to burn both fires pretty hot, no smoldering if I can help it. Both types of wood burn just fine, but I have to shove more pine though to get the same amount of heat as the hardwood so it's easier to use that in the house and reduce my trips to the greenhouse.
I let both stoves go out overnight, relying on the heat pumps in house and heat stored in the greenhouse water storage system while the stoves are cold. I've found I only have to sweep my chimneys once a year and dont ever have more than a little creosote in them.
I'll start.
