finalius
I plan to build a 3 phase (230V) grid-couples ESS with rouhly 150kWh storage. I don't want/need any emergency power or off grid support. I've searched the forums and internet in general and came up with the following components:
I've attached the schematic I came up with. With this setup, the busbar should not see more than 250A of current at any given location. The idea is that all battery cables have the same length (they come with the battery, so that should be easy) and all inverter cables would also have the exact same length.
The inverters would always run coupled, i.e. they should always create the same load (inverting or charging) on the DC busbar.
My question is that I see two seemingly contradicting statements: Victron says in their 3 phase presentation that you should connect all the inverters to one bus bar and hence don't split the batteries. But I also read frequently (on here and from Victron) that you shouldn't connect more than 4 batteries in parallel, because balancing the batteries gets tricky.
Do you think my schematic is a good design or how can it be improved?
Also, I don't need to go with the exact components I've chosen, so if you have different recommendations, I'm all ears!
- 10x Gobel Power GP-SR1-PC200 (EV280 or EV314 Cells, depending on availability, for a total of 144 or 160kWh)
- 3x Victron MultiPlus-II 48/15000/200
- 4x Victron Lynx as Busbar
- Victron Erkano GX
