How to Connect Flow Switch to Pump with a Long Distance in Between?
jolondon
Costa Rica
Hi. I am planning on installing a Grundfos SQ pump for my well here in Costa Rica. I have an EG4 6000 XP and four 100 AH batteries.
The issue is that the tanque is 660 feet from the well. How can I operate a float switch from that distance. Seems like they are designed to have the switch next to the pump and tanque in one location. Any thoughts would be appreciated.
Instead of the float switch being near the pump, the relay is near the pump, and the float switch only has to control the relay coil.
A float switch just need to have wires ran between it and the pump. Distance is not an issue. Some pump controllers have an input for a float switch. The SQ does not have those inputs so you have provide a relay capable of switching the power between the pump and the power source.
Thank you. Can you explain a little more how the pump works with the relay and the switch? I don't understand.
It sounds like you might be early in building your electrical and pumping skills.
YouTube might be a great place for you to spend some time.
Here's one about relays.
You're right, I have the SQE pump and the controller. The SQ is just soft start pump. Sounds like relay and sensor soultion.
