I'm repeating myself but here is a chart of 16 cell voltages showing how the high IR cells go high at 100% and then immediately go below the low IR cells as soon as charging stops. The second chart is the cell voltage delta between the high and low cells. There is a peak at 3.55v and then a second peak as charging stops and the voltage of the high cells drops below the low cells.
I tried balancing tighter, to 30mv, but this just made the delta greater during discharge. The tighter I top balance the more SOC is shifted from the high IR module to the low IR module, which if taken far enough would reduce the dischargeable capacity of the battery. In order to maximize capacity I'm balancing only enough so that the high cells stay below 3.6v (an arbitrary threshold).
If I could stop charging at 3.5v the delta would be much lower, and if I could stop at 3.45 it would be such a non-issue that I would probably just top balance to 10 mv like I do my other batteries. There would still be the issue of current sharing but that's a separate thing unrelated to balancing. But Seplos in their infinite wisdom has essentially hard-coded the charge voltage to 3.55v. They told me that if they allowed customers to charge to a lower voltage they would have customers complaining they aren't getting full capacity from their batteries. :-|
