whatismouse
- Oct 11, 2020
- 76
One of my cells is not like the others...
But how do I determine if it's a fault with the BMS or simply a weak cell (actually pouch)?
I did a discharge until BMS cut-off due to cell 1 being at 2.5V. Cells 2-8 were +/- 3mV of 3.260V.
I called Bigbattery support and they had me do a BMS re-set: unplug for 30 seconds, plug back in, and charge to 100%.
Here were the voltages at 100% charge:
3.364
3.661
3.657
3.657
3.653
3.441
3.651
3.667
I let the battery rest 90 minutes and measured again:
3.344
3.483
3.490
3.492
3.496
3.367
3.494
3.514
I discharged halfway-ish and measured again:
3.248
3.306
3.306
3.306
3.307
3.306
3.306
3.306
I'm not quite sure how and when the BMS functions as a cell-balancer. It would appear that under discharge, cells 2-8 are being balanced. But at full-charge, there is greater discrepancy between cells.
How likely is it that the BMS is simply not balancing cell 1? Or is it more likely the case that it is weak? But even so shouldn't in some cases the weakness of a cell be overcome by the BMS' ability to balance voltages?
I will continue trying to reach out to BB but customer support is hit or miss, and I wonder whether they've flagged me as a hopeless complainer because I've had so many issues...
3.364
3.661
3.657
3.657
3.653
3.441
3.651
3.667
3.344
3.483
3.490
3.492
3.496
3.367
3.494
3.514
3.248
3.306
3.306
3.306
3.307
3.306
3.306
3.306
