Ohms_Cousin
- Nov 6, 2020
- 194
I wish to put PV on my sail boat. My Boat/inverter system is 48v (Victron). Because space is very limited on a sail boat I can only manage a total of 4 panels with possibly 2 extra down each side mounted vertically - so if did that it would be 8 panels in total - (but not sure if that is a good idea or not to side mount like that - some do it, others say avoid it).
The issue is I dont want to run the string in series due to shading issues (boom/mast/rigging wires/sails when under way). Parallel is not much use to me in this scenario as I need to get the voltage at least 5v above battery voltage which in this case is 61v min (battery is 56v fully charged) - panels are around 40v each (not selected the panels yet but they all seem to be in the 38-45v range per panel).
So if I go with a Victron 100/20 48v MPPT I would *have to* run the string in a series config to get the voltage I need.
If I do put panels along the side grab rails they would have to be much smaller panels then I would want for mounting over the stern awning. I would like 600w+ x 2 permenatly fixed to the stern awning and a further 2 600w+ on a rail system that slides out to reveal the 2nd PV panel under the permenatly mounted one.
For the side mount panels I would need to go down to a 300/400w panel in order to fit the area for mounting better.
So what a mess.....!! 2 x 600w panels - one facing slightly East and one facing slightly West that are permanently mounted to the awning, 2 x 600w that slide out on rails from under the main 600w panels and 2 x 300w panels down each side of the boat - so again 2 x 300w facing east and 2 x 300w facing west.
Even if I were to favor an MPPT per panel to overcome the shading/orientation issues there is the problem that one panel is not high enough in voltage to start the MPPT.
So how to do this ?
So how to do this ?
