I have a 12v lifepo4 battery with a 1500w inverter and various dc loads (fridge, lights, phone/laptop charging, misc outlets). I was thinking the best way to wire it up is to have one line directly from the battery to the inverter with a bolt on fuse, then another wire going from the battery to a fuse block that will be the distribution center for all the dc loads.
How exactly do I go about doing this? Can I use 2 bolt-on fuses of different sizes on the battery terminal? I am trying to keep it to 2 separate wires because the current is drastically different between the dc loads and the inverter, but I'm just not sure how to actually go about wiring it.
