CourtJesterau
I have a deye inverter and 4 x 280 AH batteries in parallel each with a 200A pace BMS
Over the last couple of weeks I have been playing around with the settings on the Pace BMS trying to get the batteries to switch over to a 100% SOC
The Deye inverter uses the pack OVP alarm voltage set in the pace BMS to set its charging voltage
I have this set to 57.4v and OVP protection set to 58.4v and release at 57v
cell OVP is 3.65 and release is at 3.55v
the "pack full charge" voltage is set to 57v and 2000mah set for the full charge current
either battery 1 or 2 generally does not reset to 100% SOC even though they are at 57.4v and are not drawing any more current i.e. well under 2500mah
screen shot of bms below The only reliably way I can get it to reset to 100% soc is to force the pack into OV protect by settings the OV protect to 57.3v and then it resets the SOC to 100% but surely this is not how it should be done my understanding the settings I ahve now should be reliably setting it to 100% soc all ready and ideas as to what might be going on?
