The entry opening on these inverters is rectangular and has a flimsy plastic frane around with a split which promptly falls off.
My cables coming in are power point type double insulated wire and its in a 25 mm round plastic flexible pipe .
There is too much close wiring and boards to just drill a round hole.
Has anybody found a successful way to fix the flexible to the housing so no fingers can get to the wires and they don't pull out?
A raceway /box type arrangement still has wires going up to the inverter.
