svetz
Works in theory! Practice? That's something else
In most U.S. states, grid-tied Solar PV is less expensive than paying the grid for power, and unlike your power bill the prices won't rise due to inflation.
But in order to save money and go green, you need to spend money. What do you do if you don't have it?
(The idea for this thread was Courtesy of @circus, thanks for the poke! Sure hope it helps folks ; -)
Goal
This thread is about members sharing ideas on how to finance a solar PV residential array for everyone that wants to go green, save money, or both.
What's Solar Cost anyway?
To get the ball rolling, we first need to establish a $/kW for solar. Using Tesla as a baseline for lowest cost installed, it's about $2/W. DIY is around $1/W. In Australia, the price for an installed system is $0.50 to $1.00.
@upnorthandpersonal has conducted what is perhaps the most significant citizen experiment in modern times and much talked about on this thread, a 10kW solar system with 28kWh LiFePO4 battery, inverter, BMS and charge controllers for under $12k U.S. dollars. You can't get the prices he did in the U.S. due to tariffs, but for folks outside the U.S. who can handle DIY he's the best starting point I can recommend.
For the U.S. let's get rid of the battery (not needed and prices are still plummeting, you can get one later). Every little bit helps, so let's start with a 5 kW grid-tied array and assume an insolation of 4.5, as the average house consumes under 1000 kWh/month, so a 5 kW array is about 80% of the power most folks need
Not doing any shopping around, the first kit I came across was a 5 kW SMA kit for $6,163, it includes everything needed (except racking) plus engineering materials to get the permit approved. There's a federal credit of 26%, so that brings the cost down to $4,561. If you really shop around you could probably do better. But, you'll also run into unexpected stuff that will increase costs.
Many states and local areas also offer increased incentives. For example in Florida, there is no sales tax on PV gear. It pays to check!
What's the Grid Cost anyway?
Here it's $0.133/kWh, the average U.S. cost 14.3 cents. Some places are a lot less, some have time-of-use pay structures making it very complicated. Inflation of electricity in the U.S. is around 2%, although with the U.S. effort to be net-zero by 2050 it's anyone's guess what the next 30 years will bring.
Above we went with a 5 kW array and an insolation of 4.5, that's 22.5 kWh/d or 8212 kWh/yr which at .133/kWh is $1092/yr savings. So, the break-even point is about 5 years. After that, you're making $1092/year (actually more if you count inflation). Panels are typically warrantied for 20 to 25 years, so that's about $15k to $20k returned on your investment (panels do work after that, but efficiency drops a bit every year).
But it's very dependent on your net-metering agreement. In some places, you won't get paid for the power you produce. It's wrong, and you should write your state officials and congressmen about it.
Wait? That's better than $ in the bank?
Currently yes. Let's look at it as if you were investing in a stock that pays monthly dividends [ref]:
Interest on most savings accounts right now is about 0%. Investing in solar allows you to put your money to work in ways that pay you back.
Perhaps it's cheaper than you thought and you can pull $ from savings and put them to work for you rather than make no money off it.
If not, hopefully, subsequent posts will strike upon the correct combination of factors that will enable you to not only go green, but save money while doing it.
In the meantime, you might also enjoy this thread as it's even cheaper to use some easy tricks to reduce power consumption.
Goal
So dare to dream!
Build out your system on paper, estimate the costs. People on the forums have been there, they know your fears and concerns, they can and will answer your questions.Perhaps it's cheaper than you thought and you can pull $ from savings and put them to work for you rather than make no money off it.
