Hey
@OffGridInTheCity - This is super helpful. I appreciate you bearing with me trying to understand. What is the value of the ATS ahead of the MTS.
The ATS feeds power to the MTS via the "Generator Input" of the MTS. Normally you'd just feed in generator power but by replacing the generator with an ATS you can feed grid (circuit from the main panel) or the inverter and the ATS will choose automatically. The MTS doesn't care.
I know it sounds complicated or circular but it's not. It's 3 steps....
1) You wire 240v/120v from the main panel -> grid relay of the ATS.
2) You wire 240v/120v from the solar inverter -> gen relay of the ATS.
3) You wire the output of the ATS -> MTS generator input.
All standard 6awg (50a) wiring, all ETL (or UL) parts.
If you only need 120v @ 30a, you can use a Go-Power ATS (also ETL) and it's even simpler and is only 120v. They make 120v only MTSs as well.
Since the MTS is a manual transfer that requires physical intervention, wouldn't that render the ATS useless? In that case are you essentially using that MTS as a mini-subpanel since you are never changing the switch positioning so that you can use the ATS to power multiple circuits?
Yes, the MTS serves the same function as a 'critical loads subpanel' except you can choose individual circuits instead of all or nothing. But this is different than routing power to the overall subpanel (or MTS). In a critical loads subpanel situation you have grid coming in AND generator/inverter coming in and you switch manually via a breaker interlock. The ATS replaces the 'manual interlocked breakers' and is automatic.
The MTS give you 3 choices for each circuit via a toggle switch for Line (grid), Gen (ATS in this case) or Off (nothing).
With the MTS I can switch each individual circuit between grid all the time or the ATS (grid or inverter). One circuit can be grid, the next ATS and so on. This let's me choose 1 thru 10 circuits and I can vary the total load on the inverter. They make MTSs for 120v only or 240v/120v with 4 thru 10 circuits - you don't have to do 10 circuits.
Also, if you used an ATS to a subpanel would the ATS be safe enough to keep any power backfeeding to the grid or is the MTS necessary?
The MTS wiring keeps all this separate - it's not possible to backfeed anything and it's not to bad to wire into you're main panel. The wires are all numbered and colored and there are several good youtubes on hooking up a Pro/Tran2 (or Reliance) MTS - these might help you understand better. Search "Protran2 Installation".
This is super helpful as this is how I'm imagining my setup would work.
It works really well for me but... there are 2 downsides......
1) The switch from grid to inverter (and back in particular) is not quite fast enough for computers and sensitive circuits. So I use an APC UPS on my computers and Tivo/TVs to take care of this. Refrigerator, cooktop, dryer, washer, microwave, etc etc are OK/remebber their settings even with a quick loss of power during switch-overs. And no, modern refrigerator motors etc don't have a problem with mis-matched sine-waves during switch over.
2) I have 4 x Progressive ATSs and have had to replace the relays on 2 of them after 5 yrs. After ~3,000 switch-overs (twice a day for 5 yrs) I've had the mechanical relays 'stick' in position on grid every now and then and it got progressively worse. I've adjusted my PV -> Load now so that I only do 100 switch-overs / year instead of 700 so it will take a really long time to get to 3,000 switch-overs. But it wasn't hard to buy a new unit and switch the internal relays within the existing metal box - just unscrew some wire and re-screw on new relays. This avoids the whole metal box / conduit removal / replace.
Final comment - when I did my system 7 yrs ago we didn't have such a nice selection of off-grid AIOs such as MPP Solar off-grid. These days there are off-grid specific AIOs have the ATS and UPS built-in + PV inputs + battery all in one box. MPP Solar LVX6048, EG4 6000XP, Growatt, and others. Not pushing any brand, just want you to realize that you don't have to do individual components to get the exact same functionality we're discussion.
For example, if you did an off-grid MPP Solar 6000w unit, you wire grid to it (just like the ATS above), + battery + PV and wire the output to an MTS (just above) or a critical loads sub-panel and the single unit does the ATS + UPS + PV + Battery + Inverter - no chance for grid back feed!. You can parallel these for 240v/120v split-phase and A LOT of power - usually up to 24,000w range (e.g. 240v @ 100a)
