How to install two PV strings to Victron MPPT ?
oshky
Hi,
I have two PV strings, 4 panels for string one + 3 panels for string 2, for a total of seven panels. Each string will have its own DC breaker. A Victron 100/50 MPPT will be used. How do I combine both strings before getting into the MPPT? I need your advice.
Thanks!!!
As long as your within voltage there are many ways, are you within the MPPT voltage range under full sun but colder conditions?
Yes, I'm within voltage range. Panels are connected in parallel.
