Currently I have off grid system with 1200w in panels and 800Ah 12v Valence XP LiFeMgPO4 batteries (6 batteries). I have victron mppt, cerbo gx, and shunt.
I have plenty of solar power at the moment so my batteries drain to 70% each night and then refill to 100% every day and I still have a couple hours of sunlight left after I get to 100 % SOC. I'd like to shift this so that my batteries will drain to 50% and then refill to 80% and then stop each day and still be able to use that last couple hours of power to produce just enough power to run my active loads only without charging the battery past 80%.
Can I do this using the Victron equipment? My first idea is to lower the absorption and float voltages down to 13.3v. This way my devices can still draw power from the panels. Any issues this might cause by running such a low float voltage? Is there a better way to control the max daily SOC?
I do plan to charge the batteries from 80% on up to 100% once a month in order to keep them balanced.
