MrPsychedelic
I know most situations call for the top to be the feed from your panels and the bottom of the breaker to the charge controller, but how do you know when you do the opposite?
Like for my midnite solar breaker, their diagram showed feed from the panels to the bottom and from the top of breaker to the charge controller. So I just followed that.
But I'm installing a different breaker in a friends system and want to make sure I'm doing it the correct way.
shop.explorist.life
This is the breaker I'm installing, not sure how to tell which way the power is supposed to feed, or if it even matters.
Solar Isolator Breaker (Single Array)
The solar isolator breaker is installed between the solar array and the charge controller to disconnect the pos(+) and neg(-) conductors simultaneously
