Is there a way I can use a VV PSU to charge a 12v LifePO4 battery, manually. Or should I steer away from this and only use a charge controller due to the different stages of charging?
I was thinking could I replace the solar input of the CC with a PSU to emulate a solar panel and benefit from the charge controller output?
I have this PSU:
Looking to quickly charge the LifePO4 30Ah / 12V without using a small solar panel, my CC is 20A max.
I have this PSU:
61.24US $ 36% OFF|Adjustable Dc Power Supply 30v 10a Led Lab Bench Power Source Stabilized Switch Power Supply Voltage Regulator 60v 5a Wanptek - Switching Power Supply - AliExpress
Smarter Shopping, Better Living! Aliexpress.com
www.aliexpress.com
