carolinabigfoot
I just received an AmpereTime 24V 100Ah and an AIMS power con120ac1224vdc smart charger which I want to use to precharge the battery before hooking it up to my solar system and which I also might want to use with my back up generator in times of need. After reading the manual for the charger and watching some tutorials on YouTube I still cannot figure out how I can tell when the battery is fully charged and/or ready to be taken off. The manual lists bulk and float charging voltages for LiFePO4 batteries both at 14.4V (in my case 28.8V since I will be charging a 24V battery). AmpereTime recommends a charging voltage between 28.4 and 29.2V and a float voltage of 27.6V.The charger will communicate through LEDs when it is in float stage or "constant current/constant voltage"-stage (absorb stage?). Should the battery come off when in float? (I almost think so.) Is there a danger of over charging the battery (it says it is a "smart charger") or will the BMS ultimately prevent this from happening?
