MrNatural22
?SW sunshine =⚡️⚡️lit up thru the darkness✌️
? My water chamber is also separate and can be detached so the blower unit can be run alone. I only get 8-9 hours of humidification even turned down to the #1 setting. I have never run it with the heater/water unit detached though.My particular unit (S9) has a separate chamber with a removable water container. It typically holds 2 nights worth, but I don't sleep a lot.
It has a temperature setting for the humidifier. Max is 86°F, and I keep it pegged there. If the water container is full, I can run it without the humidifier heat active because I do get some humidification from the air passing through the chamber, but I do notice the difference in the morning.
This particular unit is 24V. Power brick is 90W with a 24VDC 3.75A output. There are 3 pins. It's too tight for me to comfortably verify the 3rd smaller pin, but the two big ones are 24V between them, and none have voltage to the "barrel" of the plug. Rather than try to hack it, I'd just suck it up and buy the 12V converter.
My ac power brick outputs 12v to the unit not sure if it’s dual 12/24v capable but it would be nice. I have to dig out the manual stashed for 3 years somewhere. ? @DThames waiting for your results ?
Here’s the specs on my brick.
