ghostwriter66
"Here - Hold my Beer"
HOW TO KILL A BATTERY (PART#2)
So my boss who has a PhD in Chemical Engineering went to China on business about a month ago and visited one of the largest LiFePO4 battery manufacturers in the world that we use. They gave him a very good tour and today we reciprocated their hospitality by hosting their Lead Design Engineer who is in the States for an upcoming Solar conference. It was a VERY interesting day with him with lots of hands on "Show and Tell". So I thought I would pass what I can on to those interested.
So what should we do with the marketing numbers when these manufacturers state 3000 – 5000 cycles before they drop below 80% or is dead?? He states that honestly with real-world (especially RV) use, anything stated to have over 2000 cycles is kind of getting into the "wishful thinking" section.
First – these batteries are tested in a wonderful 78 degree environment. Apparently the sweet spot for LiFePO4 (LFP) batteries is 78 degrees.
Second – to get the very highest duty cycles to report – they charge the battery to the target 100% SOC value at usually .5C and then STOP immediately once they hit that 100% SOC voltage and immediately discharge them down to the low voltage limit, and then STOP and then charge back up to 100% and repeat that cycle for about 2000 more times. Doing it that way – even after 2000 cycles – they still are able to get 80% of the aH of the original.
BUT in order to get the 5000 cycles they do the same but charge and discharge at .2C - putting so little strain on the battery that they can usually get incredibly high UNREALISTIC MARKETING numbers like 5000 cycles doing it that way.
The fastest way to KILL a LFP battery is when ppl charge the battery to 90-100% SOC and HOLD it (FLOAT it) there. Also another DEATH BLOW is charge it (like Preppers) to 100% and then put on a shelf to be ready for the end of the world and let it sit. So the manufacturer tested this by charging batteries to 100% and letting it drop naturally to about 95% and then charging again to 100% and then repeating over and over. They also Charged to 100% and stored it untouched. After a year of doing this, the battery that they had Charged to 100% and stored was only able to deliver less than 1000 cycles of 100% to 0% SOC before it died. Same for the battery that did the 90-95% to 100% over and over. SO storing or keeping it fully charged for a year not only cut the cycles in half – but KILLED it after only 980 cycles.
According to this particular manufacturer – their sweet spot for charging to get the most cycles out of real world use is 80-85% to 20-25%. He actually said his personal settings on his batteries at home were 15% - 90% so take all of that with a grain of salt.
BEST WAY TO STORE LFP
The best SOC to store a LFP is 40% …is no less than 40% and no higher than 60% … Apparently 40% is another sweet spot for LFP…
