I’m trying to solve errors 10 (Output power derating) and 04 (low battery) with my Growatt SPF3000TL LVM (24V system). Here’s the setup.
I’ve a concession shack with solar panels, 2 Interstate Marine/RV (Group 24DC) batteries (wired in series with 2AWG cable), Growatt SPF3000TL LVM Inverter and an AC shore power connection (300ft 12AWG cable). My problems occur when I try to use a 1500 watt coffee maker. If I’m in utility first mode as soon as the coffee maker kicks on, the line voltage drops below 95VAC and the Growatt reports warning 10 (Output power derating). That makes sense because of the 15 amp draw on the long cable causes the line voltage to drop. I was hoping that the Growatt would then kick on its inverter from the battery and boost the voltage but it doesn’t have a boost mode.
If I’m in SBU priority mode, and the coffee maker kicks in, everything is fine for a few minutes while the batteries and inverter provide the power. However, during the operation, the battery voltage is dropping quickly until it hits the 20V cutoff voltage (set by Program 21) of the Growatt at which time the Growatt either switches back to utility (which doesn’t work) or shuts down with error 04 (batteries low). The large drop in battery voltage is mostly due to the 50amp draw from the batteries and not a drop in the capacity of the batteries. They are back to 90% when the system shuts down.
Any solutions? I’ve got Program 21 set as low as it can go (20VDC). I tried a small power stabilizer on the incoming AC but the unit I had was too small (300W) to do any good – it just overloaded when the coffee maker turned on. I tried adding a 24VDC charger (10amp) to the batteries powered from shore power to help keep the battery voltage up but that didn’t help. Now I’m thinking of using a simple Full Wave Bridge Rectifier on the incoming AC and connecting its output (40 to 60 VDC) in parallel with the solar panels. That would provide the Growatt inverter with extra power to power the loads and reduce the demand from the battery.
If that doesn’t work, I'm pretty sure that a switch to LiFePO4 batteries will solve the problem? But that's expensive.
What do you think? Will the rectifier work? Any of you Growatt users have relevant experience?
Any other solutions?
