How to tell the difference between Grade A and Grade B cells. AND why you should always pay with CREDIT CARD.
Going to make this sort of in bullet form – otherwise this will go on for many of pages of rambling which this will probably be anyway..
Before I start …25C is 77F – the perfect temperature for LFP. Remember – LFP is a CHEMISTRY – strange things start happening as you get further away from 77F… Also keep in mind that honestly – no one really understands LFP. It’s a weird chemistry – it works remarkably well – but there is still allot of voo-doo in how it works. (Voo-doo being a technical word here – LOL)
But back to Battery ratings.
There are actually (5) five accepted commercial LFP ratings in China used by commercial companies.
GRADE A+
GRADE A-
GRADE B
GRADE C
SECOND-HAND
When dealing with the Anglos, the Chinese will often refer an A+ and A- as simply GRADE A and B/C as B.
I will not discuss Grade C or second hand – I am going to say that I have seen VERY little Grade C or Second Hand here on this forum. Both are obvious – leaking – dented (badly), warpage, and both will measure 3.2V but the moment u put a load on them they crash to below 1V instantly ...
And – although not a scientific observation, but as of 2021, you can typically tell your Grade B and below simply by their packaging. The ppl that are passing off Grade B for A’s and trying to separate you from your money most usually is not wanting to waste allot of the profit in doing professional secure packaging but instead just drop it in a cardboard box – add allot of tape – and hope you don’t open them until after the dispute phase is over.
NOW – this will probably be the most important thing to take away from this. There is absolutely NO standard between each company on how they rate batteries. We have purchased some critical 3.2V 280Ah LiFePO4 batteries used for medical stuff from company XYZ that was considered GRADE C by that company BUT turned out to be better than any GRADE A+ listed by any of the normal LFP Alibaba companies.
My ex-boyfriend has an Audi R8. He loved that car. If it was a battery he would give it a GRADE A+. I hated it – you literally had to fall into the car to get in. And you literally had to roll out to get out. I could barely see over the dashboard. And the seats were hard and uncomfortable. I would give it a B-.
So batteries, as in car ratings, is in the eye of the beholder, or manufacturer – so to speak.
That’s why DATASHEETS are VITAL. And not the datasheets the VENDOR supplies BUT the datasheet of the manufacturer. !!
(Beat a dead horse time) …BUT one of the things that kills me most is when ppl do NOT read the datasheet of the particular manufacturing company they are purchasing the batteries from. This is vital. You MUST have a datasheet to compare the results you are getting to what they said you should be getting.
The first thing I do is weigh each and every battery we receive. That right there tells me if its going to meet 90% of my expectations. Testing voltage rarely tells me anything. (Heck a dead 9V battery still reads 9V). The second thing I do is an IR test.
SO the best way to know if a cell is actually a Grade A all the way thru Second Hand is look at the manufacturers specifications and compare it to your results.
The (6) six key parameters that must be checked to determine the proper grading is:
Appearance, Size and Weight, Capacity, Internal Resistance, Self-Discharging Rate, and Capacity Recovery.
Every manufacturer will grade every battery coming off the line against these 6 parameters. Most manufacturing companies have this done by computers and an automated process. But any of these 6 factors can cause an GRADE A to go to C in a heartbeat. The issue for US is that these reputable companies will sell their GRADE C’s to a distributor as a GRADE C for pennies on the dollar, and the distributor turns around and sells the Grade C to someone as a GRADE A and hope you don’t test IR or Capacity Recovery or something before its too late to dispute. ALIBABA is VERY much against companies doing this and will support you in getting your money back for this.
APPEARANCE: Each battery is produced with a QR code that allows the end-user (YOU) to get information about the battery and get assistance for warranty and customer service. …. In China, Grade B cells do NOT have a warranty, so 100% of the manufacturers will scrape off the QR code before pushing them to a reseller as B-Grade. Sometimes the manufacturer will not scrape the QR code but simply put a new black insulating panel over it. Either way – missing, scratched, or covered with a black strip -- its a GRADE B cell (normally). If there is a QR code under the strip of black plastic – IT’S A GRADE B….
SIZE AND WEIGHT: So this one is a little tricky. Batteries will be different size and weights at different SOC and temperatures. You would need to ask the manufacturer what temperature and SOC they used in their testing so you have the same baseline to judge yours from. BUT if its bloated like a football or weighs like a feather – good signs its not Grade A - LOL. If the datasheet does give SOC and temperature at time of testing – and your battery does not meet the requirements within a range of error – then you’re probably looking at a B.
CAPACITY: Another pet peeve of mine. For LiFePO4 batteries – worldwide – the standard testing criteria is 25C with a charging and discharge of 1C. Testing any differently will get you different results then the data sheet because of temperature and charge / discharge variances. Different temperature deviation from 25C on LiFePO4 has a measurable difference on capacity … with that said – often times its minimal but the baseline testing worldwide is at 77F at a 1C charge and discharge.
INTERNAL RESISTANCE: This is an important one – making LFP batteries is complicated – it truly is. Some companies have this down to a science – others – not so much so. TONS of things can go wrong. TONS!! Going from materials to a finalized battery is a complicated 7 step process – and along that step a million things can go wrong – from bad materials to a microscopic tear in the combining sheet to the sheet tearing at the end, to etc etc. IR testing is a good way to see if everything is working on the inside. Again temperature and SOC from the datasheet is required. Most manufactures will suggest an AC internal resistance test but most of the end users like me utilize a DC IR reader. I’m lazy and its quicker and virtually just as accurate ….
SELF DISCHARGING RATE: So self-discharging is calculated by looking at the how fast the voltage is decreasing from its last SOC. As we all know with LFP – its pretty much a flat voltage line from 10-90%. So a battery at 100% state of charge will have a quicker discharge rate then one at 50%. So again – the data sheet is vital to see what the SOC was that they tested at. Now to be honest, YEAH there is a complicated formula they taught us in school and you need to let it sit for 90 days at 50% SOC in a room with a stable temp of 25C and this and that and to be honest – I normally skip testing this … But just in case you wonder anything UNDER 3.51% loss per month is considered GRADE A.
((SIDE NOTE)) – In China MOST GRADE A- cells being sold as GRADE A- is ONLY being sold as A- and not A+ because they have been sitting on a shelf for more than 6 months. Seriously – often times that’s ALL it takes for a manufacturer to drop it from a + to a -. And if a battery is going to last 13.5 to 15 years then 6 months to a year sitting on a warehouse shelf is nothing.
CAPACITY RECOVERY: This one is pretty straight forward – also known as Depth of Charge testing or – DOD. Just do a 100% charging and then 100% discharging and then 100% recharging. If the datasheet says that the Capacity Recovery rate is 100%, and you charge the battery to 100% after a discharge to 0%, then you are fine – if it charges to 98% (for example) then you have issues. Capacity test is how I find 99% of my bad batteries.
Finally a couple of notes from our real life measurements of 1000’s of various batteries….
Note 1.
Using a 280Ah battery as an example:
At 0C we get 85% capacity
At 25C we get 100% capacity
At 40C we get 80% capacity
Note 2.
For the last 1000 LFP batteries we have got in, 11% of my batteries did NOT match the datasheets requirements BUT they were good enough for what we needed. Some were off only by 2-3 Ahs … For example most of the 89% barely made the rated 280Ah and many of the 11% only got between 272-280%. Good enough for me BUT we did not get what we paid for. Being a bored angry Asian girl out in the middle of the West Texas desert, I normally tell Alibaba that if I paid $100 for a battery and its missing 5% of the Ah charge I paid for – then I want $5.00 back. Now multiply that by a 100 “bad” batteries and it comes to real money quickly … and often times I am successful in getting compensation. Most companies would rather pay you a few dollars back then deal with the pain of doing the right thing. AND if we all start complaining then they are less likely to pass B's off as A's.... Remember - they don't get paid UNTIL after the Assurance Deadline passes.
I think that’s about it.
sorry for the rambling.
Thx
