I'm about to start living in my off grid home and I want to get and EV eventually. I realize I would need v2h capabilities, let's assume i have this.
How do I go about doing this? I know my 6500ex's aren't capable, but what could I add to my system to achieve what I want to do? I would not mind running a dedicated circuit(s) for the ev(s) to make it work. Ultimately i want my house and house battery to be able to charge from my EV, but also to charge the ev from my PV system when the house battery bank becomes full. Basically I want to prioritize my usage from solar, ev, then my house bank. But i want to prioritize charging my house bank, then my EV. Yes I realize my EV battery will lose range from doing this, but that is the entire point of why I want it to work this way. I have many vehicles and don't need to drive the ev every day and I'll probably get two anyways but I'd want both to be setup the same way with the possibility to charge one from the other (without direct plug in to each other) under certain circumstances. I love the idea of charging my car at a public station (many are free around me) and using that energy to power my house and charge my house battery, especially during stretches of clouds and pretty much eliminate the need to run a generator ever.
I researched it a bit and supposedly using a grid tied inverter and using the car as the grid is not safe but I don't understand why. That seems like the obvoius, cheapest, and easiest solution to me...TIA!
